Camster100
May 30, 2019Tutor
VPN Xbox and Kodi
Hello I've just joined the community to ask this question. I appear to have a problem but one I'm sure the community can help with. I can't streem 4k on kodi although I believe my connection should...
Camster100
Jun 01, 2019Tutor
I'm thinking the xr700?
Netduma-Fraser
Jun 01, 2019NetDuma Partner
If you don't need a VPN then I would suggest you use it without it and then combined with QoS you should definitely be able to stream in 4K. Maybe I should check kodi out! The XR700 would definitely give you superior WiFi range/speed if your connection is fast enough.
- Camster100Jun 01, 2019TutorKodi is awsome bro and runs so well on the Xbox the interface is brilliant...... My 1080p actually looks like my own tvs 4k
