xlr8r's avatar
xlr8r
Luminary
Mar 06, 2018
Wake on Lan not working on this router
Hi All
been having a few probs getting my new XR500 to work with WOL
(upgraded from an R7000 running dd-wrt which worked fine...)
I also use an mobile app "iShutdown" which can wake, sleep, hibernate, shutdown etc my pc at home while im outside of my LAN.
this app and any other WOL app i usually would use , no longer works with the XR500.
this is a big no no as i frequently need to check in on cctv , nas, home pc etc etc.
Have port forwarded usual ports for the app and port 9 for WOL, but it just doesnt seem to work.
Have i to do some special tweak on the XR500 to get this working ?
thanks
  • Hey if you've seen my last post on the Netduma forum I would highly recommend calling Netgear Support so that you can get it resolved as quickly as possible.
    • xlr8r's avatar
      xlr8r
      Luminary
      I opened an email ticket with Netgear Support for assistance
      thanks
      • Netduma_Jack's avatar
        Netduma_Jack
        NetDuma Partner
        Hi xlr8r, that's great to hear. I hope they're able to get to the bottom of this quickly :)
        Please let us know if you have any questions!
