aj10333
Aug 30, 2023Follower
WAN Port not working!!!
Good evening all, I have had my router for a little under a year now. It has been mounted on my wall since the day I set it up. I literally havent touched it. My WAN port no longer reads cables a...
Aug 30, 2023Guru - Experienced User
Is this regarding the XR1000 router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
