aj10333
Aug 30, 2023Follower
WAN Port not working!!!
Good evening all, I have had my router for a little under a year now. It has been mounted on my wall since the day I set it up. I literally havent touched it. My WAN port no longer reads cables a...
Netduma-Fraser
Aug 31, 2023NetDuma Partner
You can download new firmware from a device able to get internet such as your phone or one you can connect to your ISP modem/router and then upload it manually to the router - it doesn't require internet for that purpose. Do you have access to the interface at all? What steps have you taken so far, a reboot or factory reset for example?
