Rompy
Oct 29, 2019Tutor
Wan port or not
Hi guy just move to EE fiber broad band and there bright box 2 modem /router has no modem mode but has a wan port could you tell me best set if I use wan port or best set up just of Ethernet port one ...
- Oct 30, 2019The IP you did was fine, you did it correctly. I would recommend you follow our optimal settings guides to get the most out of the router: http://support.netduma.com/en/support/solutions/folders/16000090646
Rompy
Oct 30, 2019Tutor
If I remove static ip from Xbox I think it will change ip on Xbox every time I boot it up
Netduma_Alex
Oct 30, 2019NetDuma Partner
If you set the IP as reserved on the router, then the router will give it the same IP address every time.
An IP address reservation makes the router keep the IP unoccupied ready for the Xbox.
A static IP is more like the Xbox demanding an IP that the router might not have at the ready.
- RompyOct 30, 2019TutorOk thanks my static ip is 10.0.0.125 on Xbox and this is what I have put in net gear Reserved ip so if I go on Xbox now and set connection to Automatic should it all work ok
- Netduma_AlexOct 30, 2019NetDuma Partner
That's a strange IP address... What is the IP address of your router?
- Netduma-FraserOct 30, 2019NetDuma PartnerI assume your router LAN IP is 10.0.0.1 is that right? If so that IP is fine. You can only put one device in the DMZ but keep UPnP open and the other console should be fine for NAT.
my moden ee bright box ip is 95.144.148.162 the netgear xr500 wan ip is192.168.1.164 so do i need to change resvered ip address in netgear if so any ideal on what ip to use i just look the lan ip on netgear is 10.0.0.1 another thing is there away to get ping low has possible with netgear router
- Netduma-FraserOct 30, 2019NetDuma PartnerThe IP you did was fine, you did it correctly. I would recommend you follow our optimal settings guides to get the most out of the router: http://support.netduma.com/en/support/solutions/folders/16000090646
ok and thank you to all you guys for your help
- FURRYe38Oct 30, 2019Guru - Experienced User
Looks like you have a router built in to your ISP Modem already. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Rompy wrote:my moden ee bright box ip is 95.144.148.162 the netgear xr500 wan ip is192.168.1.164 so do i need to change resvered ip address in netgear if so any ideal on what ip to use i just look the lan ip on netgear is 10.0.0.1 another thing is there away to get ping low has possible with netgear router
