Rompy
Oct 29, 2019Tutor
Wan port or not
Hi guy just move to EE fiber broad band and there bright box 2 modem /router has no modem mode but has a wan port could you tell me best set if I use wan port or best set up just of Ethernet port one ...
- Oct 30, 2019The IP you did was fine, you did it correctly. I would recommend you follow our optimal settings guides to get the most out of the router: http://support.netduma.com/en/support/solutions/folders/16000090646
Rompy
Oct 30, 2019Tutor
Ok thanks my static ip is 10.0.0.125 on Xbox and this is what I have put in net gear Reserved ip so if I go on Xbox now and set connection to Automatic should it all work ok
Netduma_Alex
Oct 30, 2019NetDuma Partner
That's a strange IP address... What is the IP address of your router?
