Rick6922's avatar
Rick6922
Luminary
Jun 28, 2019
Wan setup
in WAN do I put the number I assighned my xbox1x if I want if I want it a default DMZ server?
  • FURRYe38's avatar
    You can however it's not needed. You only need uPnP enabled on the XR router and connect the xbox to the router via wifi or wired. Wired is preferred. Disable Instant ON on the xbox as well. If the xbox isn't fully connecting, press the front power button on the xbox until it shuts off. Then turn it back on. This will clear out any bad networking cached configurations.
