Marv-K
Aug 30, 2021Guide
Warzone , Bot Lobbys , geofilter , vpn /already possible!
Hello dudes! I recently played warzone (duos) (fill up) with someone (jagra) and found bot lobbies with a netduma router. He used the geofilter, VPN and a live lobby KD tracker app. Unfortunately, I o...
Marv-K
Aug 31, 2021Guide
If I set the location to Brazil with VPN, for example (only example) and the geofilter to the location Brazil, will I find the best ping games in Brazil? Someone just told me he uses geofilters for bot lobbies and a live tracker for cod lobbies. But unfortunately I can't find a Cod Live Tracker anymore. Because it allegedly violated Activision guidelines at the time and the providers had to deactivate live tracking.
But it generally seems to me that the geofilter does not work for me. Even if I use it for my location.
Netduma-Fraser
Aug 31, 2021NetDuma Partner
You will still have a high ping because you do not live in Brazil, the VPN will also add additional latency. Can you explain how it doesn't work for you in your location?
