josephquake
Feb 18, 2021Tutor
we need stronger options to play quietly with a specific ping
I have to find 10 games to be able to play 3 games that makes me very tired of all that I would like to request an option that allows blocking a specific ping
Netduma-Fraser
Feb 18, 2021NetDuma Partner
What are your Geo-Filter settings? It sounds like you may just need to restrict your radius a bit more to the servers you know play well.
- josephquakeFeb 18, 2021Tutor
It is not working I choose Chile and it keeps putting me in Brazil
- Netduma-LiamFeb 19, 2021NetDuma Partner
Is that where you're located, in Chile?
What value is ping assist currently set to?
- josephquakeMar 05, 2021Tutor
I am requesting an update since it is not working at all well
