Whiskey8
Mar 10, 2022Guide
Weak Signal Zero Distance
Model: Nighthawk (XR1000) AX5400 - Couldn't find that model in the dropdown for model number. PurchaseDate: 8 March 2022 FirmwareVersion: 1.0.0.58 Current GUI Language Version: V1.0.0.46_2.1.46.1...
Netduma-Fraser
Mar 10, 2022NetDuma Partner
Try these suggestions:
Disable Smart Connect, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds
Use a WiFi analyzer to find the least congested channel and change to that
Set the antennae to this position _ | | _
- Whiskey8Mar 10, 2022Guide
Will try all above and follow up. Thank you for the tips.
