droesw
Dec 23, 2019Guide
What exactly does traffic prioritization do?
In the QoS page I notice that under Traffic Prioritization it has All Devices and DumaOS Classified Games enabled by default, but what exactly is this setting do? Does having this turned on or changi...
Netduma-Fraser
Dec 24, 2019NetDuma Partner
With that setting enabled Traffic Prioritization will automatically detect and prioritize game traffic. It puts your game packets ahead of the network queue in order to minimise jitter/ping spikes that would be otherwise caused by your other devices. It isn't a setting for speeds it's purely to help improve your ping when gaming and keep the connection as stable as possible so I would recommend you leave this enabled.
droesw
Dec 24, 2019Guide
I have 3 other roommates who also play on xbox one. Is there any way I could modify the settings so that I can even get the prioritization over them to make sure my ping is always the lowest instead of them getting the same prioritization?
- Netduma-FraserDec 24, 2019NetDuma PartnerThere is no way to set a priority list within the feature but you could disable DumaOS Classified Games and then add your console with the games console service. That would prioritize your console but not theirs.
- droeswDec 24, 2019Guide
Like this? (I attached a screenshot) Also do the percentage sliders for download and upload affect latency/ping prioritization at all or does that just affect upload and download speeds?
- Netduma-FraserDec 24, 2019NetDuma PartnerYes exactly like that. Yes it can do, if you've got local congestion or even if a device randomly starts downloading something that can cause lag/your ping to rise so by utilizing that feature you can prevent that and keep your ping as low and stable as possible.
