usermac
Dec 14, 2018Luminary
What is the changelog for firmware V2.3.2.40 XR500
I see there is a new firmware update for the XR500 and I want to know what changes are coming with this update.
Could this finaly be the update with all the new features that the DUMA OS should...
- Dec 15, 2018
Netduma-Fraser
Dec 15, 2018NetDuma Partner
They likely want to do a staged rollout so if there are any issues it won't affect the majority of users
liberie
Dec 16, 2018Aspirant
Did anyone have the same problem ?
at Dashboard i'm getting a error
Uncaught ReferenceError: start_cycle is not defined
- packetdropDec 16, 2018Star
Yes. I actually tried to post a report and solution for it here already but it didn't make it through apparently. In any case here is my problem description and a solution that worked for me:
Nature of the problem: One of the pinned panes on the dashboard is related to the error report. For me it was the top right corner.
Solution: I kept unpinning the pane in the system information page and go back to dashboard to see if the error is gone. After unpinning two panes the error disappeared. I repinned, and all was back to before without the error.
- liberieDec 16, 2018Aspirant
Thanks that solved the issue
I see a really high CPU usage after this update , is the case on your XR500 too ?
I never paid attention to that. Currently I see on average one cpu at below 20% and one below 40%. It can peak occasionally but that is where it is typically. Haven't noticed any performance issues network-wise so had no grounds to be worried. CPU usage does not concern me unless there is an impact on network performance.
