Billyfair
Aug 02, 2018Tutor
What is the difference between the XR450 vs XR500?
Recently saw the XR450 at costco for around $250 and was amazed at the price. What is the difference between the XR450 and XR500? Will I notice any real world differences between the two?
- Aug 02, 2018
XR500
AC2600 (800Mbps @2.4GHz—256QAM
support +1733Mbps 5Ghz 11ac)XR450
• AC2400 ([email protected]support+1733Mbps@5GHz 11ac)$100 cheaper difference between the two models is the 2.4Ghz radio. XR450 is only available at Costco
Netduma-Fraser
Aug 02, 2018NetDuma Partner
Only difference is slightly less WiFi speed I believe.
- BillyfairAug 02, 2018Tutor
Will a person fell a difference in real world usage?
- Netduma-FraserAug 02, 2018NetDuma PartnerUnlikely unless you have ridiculously high WiFi speeds
Only have 100 down and 10 up. Thank you for the response!
