A7H7M7E7D71
Dec 27, 2019Tutor
what is the diffrence between XR450 and XR500 pro gaming router
Hi everyone ........ I have gaming pc and i'm always playing online games on it , soooooooo i'm wondering what's the diffrence between XR450 AND XR500 NETGEAR pro gaming router ?????? i found...
Netduma-Fraser
Dec 28, 2019NetDuma Partner
The WiFi is slightly weaker on the XR450, that's the only difference and you'd be unlikely to notice the difference anyway. Would recommend going for the XR500 if it is cheaper.
A7H7M7E7D71
Dec 28, 2019Tutor
The XR450 is cheaper about 100$ than XR500 , and i just use it for my pc only with Ethernet cabe.
- Netduma-FraserDec 28, 2019NetDuma PartnerGo for the XR450 then as you won't notice a difference and your bank balance will thank you!
- A7H7M7E7D71Dec 28, 2019TutorThanks for advice , i appreciate
