Trazix
Aug 08, 2018Aspirant
What is the real utility of QoS ?
Hello,
So I just setup the router with 2 computer connected. I was looking into the QoS option so I did a test with my main computer at 99% computer and the second at 1% of bandwidth and I started ...
- Aug 08, 2018Thats normal as share excess is enabled which basically means if a device isn't using bandwidth it will give it to another device that needs it. If you disable share excess then it will work as you envisaged.
Netduma-Fraser
Aug 08, 2018NetDuma Partner
