Trazix
Aug 08, 2018Aspirant
What is the real utility of QoS ?
Hello,
So I just setup the router with 2 computer connected. I was looking into the QoS option so I did a test with my main computer at 99% computer and the second at 1% of bandwidth and I started ...
- Aug 08, 2018Thats normal as share excess is enabled which basically means if a device isn't using bandwidth it will give it to another device that needs it. If you disable share excess then it will work as you envisaged.
Netduma-Fraser
Aug 08, 2018NetDuma Partner
Trazix
Ah I see thank you for that but its still wreid when I enable something for download on the other computer (torrent or p2p) it take the priority of my full bandwidth without share excess while I am playing
- Netduma-FraserAug 08, 2018NetDuma PartnerIf you've added it to Traffic Prioritization that'll be why. Its only meant for low latency applications
