nodnarb
Apr 13, 2020Aspirant
what router for nighthawk cm1200 modem
what router should I use with this modem, I also am curious if there are any extra settings to help with latency. Also would getting my own nighthawk router help with ping?
nodnarb
im not really interested about wifi mainly, im gonna be using a ethernet. Im mainly just looking to increase consistency with latency.
Apr 13, 2020Guru - Experienced User
nodnarb wrote:im not really interested about wifi mainly, im gonna be using a ethernet. Im mainly just looking to increase consistency with latency.
Statement didn't really help at all.
If you're not looking at wifi, then just directly connect to the modem. Least amount of latency as its a direct connection.
If you're looking at running more then 1 device, then look at a gigabit router. And then again it comes back to details
- nodnarbApr 13, 2020Aspirant
The main concept 'm trying to ask is, would there be a point to get a nighthawk router on top of the modem, regarding to latency or does the router only matter for wifi and multiple devices.
- plemansApr 13, 2020Guru - Experienced User
nodnarb wrote:The main concept 'm trying to ask is, would there be a point to get a nighthawk router on top of the modem, regarding to latency or does the router only matter for wifi and multiple deviceI
it does add a bit of security and other features.
- Netduma-FraserApr 14, 2020NetDuma PartnerIf you have multiple devices then a router can provide QoS to allow them to use the internet at once without causing each other to lag/buffer. You are in the Pro Gaming section so that router range is what I would recommend as the QoS will eliminate any local congestion you would get.
