martyr444
Oct 04, 2020Apprentice
What Security Improvements with latest XR700 Firmware
Hello, I would like to know how much or more details on what Security improvements were added for Version 1.0.1.34. I tried to just upgrade the Firmware from Version V1.0.1.20 and it causes my Conten...
martyr444
Oct 05, 2020Apprentice
Hello, I know that many Netgear Routers have been known to have vulnerabilities. That's why I wanted to get more details on what this fixed in making the XR700 more secure. I went ahead and set my XR700 back to Factory. I then configured everything to find out if using a backup from V1.0.1.20 to recover V1.0.1.34 was causing this issue. Even with a clean install and reconfiguring everything without using the backup still have the same issue. So it's this latest Firmware V1.0.1.34 it causing the issue. I set the Content Filter Schedules the same as before so the Service blocking starts at 21:00 and ends at 7:00. The only way I get it to trigger is to go to this schedule and hit apply at 7AM which I shouldn't have to do. I can go back to the V1.0.1.20 and it will work like it's supposed to. But then I'm losing the new Security updates which is a bad idea. How do I escalate this so the Engineers can get a fix? It it's a problem for my setup, it should be an issue for all setups that use this feature. Please advise.
Netduma-Fraser
Oct 05, 2020NetDuma Partner
You would have to make a ticket here and see if they can escalate it for you: http://support.netgear.com/
- martyr444Oct 08, 2020Apprentice
I created a Ticket to support via Email. No one has resoponded. What's the next step to get support for both of these over $500 Netgear XR700 Routers. For this kind of Money and due to Security issues in the World today, I need this resolved. I need the features and I need the Security I paid for. Can you help get me some support help?
- Netduma-FraserOct 08, 2020NetDuma PartnerChristian_R DarrenM can you help please?
- FURRYe38Oct 08, 2020Guru - Experienced User
- martyr444Oct 31, 2020Apprentice
All the Firware update notes are the following which doesn't give any details on the Security fixes. We all need better security on our Devices but we need the features to work too. At this point I would either have to lose security by going back to the V1.0.1.20 so the Content Filter schedule works. If I keep the current 1.0.1.34 then I get some unknown security fixes but lose the function of the Content Filter schedule. Both are bad choices as I need both to be working.
New Features and Enhancements:
- Supports Plex media server version 1.19.5
- Supports additional ISPs from Asia in the ISP profile list on Internet Setup page
Bug Fixes:
- Fixes the SAMBA issue when the file size is greater than 2 GB.
Security Fixes:
- Fixes security vulnerability issues
I sent private messages to @Christian_R @DarrenM to see if they can get me some help on this.
I still haven't got any response offering help on this. I would be willing to test a new Beta to get this issue fixed.Right now I have had to go back to Firmware V1.0.1.20 which means Security will be an issue with both of my XR700 Routers.
