Caiden1220
Aug 22, 2019Aspirant
When i change my mac address all the fields go empty
OK so when i click on Use this max address and try to change something all the fields go blank someone please help i am trying to change my ip address or tell me a different way on changing this thi...
Netduma-Fraser
Aug 22, 2019NetDuma Partner
If you want to change those fields then you have to switch from get automatically to 'Use Static IP address' or 'Use these DNS servers'
- Caiden1220Aug 22, 2019Aspirant
but when i do that the fields are still empty and i dont know what to put in them
- Netduma-FraserAug 22, 2019NetDuma PartnerIf you don't know what to put in them then you should definitely leave it as automatic. What are you hoping to achieve by changing these settings? There may be a different setting that's more suited for your goal.
