tcc13c
Jul 16, 2018Follower
When will new VPN clients be supported for Netgear XR500?
I am currently running a Netgear XR500 router with NetDumas OS V2.3.2.22. I am trying to set up a VPN like Private Internet Access or NordVPN on this router. It appears the only client currently su...
ezambran
Oct 20, 2018Aspirant
I am interested in testing - I received my XR500 a couple of weeks ago.
My VPN provider is Mullvad.
Netduma_Jack
Oct 21, 2018NetDuma Partner
Thanks for letting us know ezambran - hopefully there will be a version to try out soon.
- smitheramOct 23, 2018Guide
Hello,
I've had the XR500 for a week and I am happy with it so far but one feature that is lacking is the VPN Client which is only available for HMA. Also I'm having problems with the VPN Service I export the config file and place it into OpenVPN but it will not connect due to a certificate problem.
- bsilverthornOct 23, 2018Apprentice
Yep same issue here, I just imported the non windows version of the config and it worked fine.
Not sure why the 700 is here yet, they don't have many of the kinks worked out of the 500 yet.
- Netduma_JackOct 23, 2018NetDuma Partner
I recommend you drop NETGEAR's official support a line about the VPN Server export problem - they may be able to fix it, but if not, they can record a ticket to pass it onto the developers (we, Netduma, are not the devs for this): https://www.netgear.com/support/contact.aspx
