tcc13c
Jul 16, 2018Follower
When will new VPN clients be supported for Netgear XR500?
I am currently running a Netgear XR500 router with NetDumas OS V2.3.2.22. I am trying to set up a VPN like Private Internet Access or NordVPN on this router. It appears the only client currently su...
Netduma_Jack
Oct 23, 2018NetDuma Partner
I recommend you drop NETGEAR's official support a line about the VPN Server export problem - they may be able to fix it, but if not, they can record a ticket to pass it onto the developers (we, Netduma, are not the devs for this): https://www.netgear.com/support/contact.aspx
alteredbeing
Dec 13, 2018Guide
Any updates?
- Netduma_JackDec 15, 2018NetDuma PartnerHi - yes, this is now out on the XR500 on the latest firmware.
Follow this guide on how to upgrade and setup your Hybrid VPN: http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn- bsilverthornDec 15, 2018Apprentice
So far so good, the only issue so far is 5 /5 vpn connections seem to not want to break 1meg on the download.
Treid differnt providers and vpns.
More testing later.
- Netduma-FraserDec 15, 2018NetDuma PartnerTry using TCP as the connection type as most speed tests use TCP
