MetFox123
Nov 17, 2022Guide
When will they update the firmware of xr1000?
Hello, Still no updates for the xr1000?? Can you guys contact the netgear team and give us some updates when they are expecting the update???
Nov 17, 2022Guru - Experienced User
When they release it. NG doesn't tell when future updates are forth coming.
Are you having problems with your router?
MetFox123
Nov 17, 2022Guide
Interface is slow and I want the HybridVPN option on it. They promised this more than 1 year ago...
I think I need to buy an Asus gaming router.. op
- FURRYe38Nov 17, 2022Guru - Experienced User
I use MS Edge and it working ok for me. Mines been online for over 10+ days. Working solid.
It's up to NG to release FW. They don't let the public know when this happens. No router Mfr does.
Your choice though. Good luck.
