JNewms
Apr 09, 2019Guide
Where to go after XR500?
Hi, I'm trying to get some opinions from the community. I was unfortunate enough to purchase the XR500, and since purchasing the device have had nothing but problems with it. For the price of the rout...
- Apr 09, 2019Gonna mark this thread as solved, as I'm not actually having any success with the intended purpose. Literally the same troubleshooting steps I've seen in every other thread that didn't work. I'll try to find another forum of people that had to buy something to replace this router. It seriously feels like this thing was pushed out to have beta testing done in production.
Apr 09, 2019Guru - Experienced User
The XR series can handle 900Mb wired speed tests...
JNewms
Apr 09, 2019Guide
My modem is a Netgear CM1000. I have reverted the firmware back to .32 since .40 is unable to stay connected to the internet.
I've seem where people claim this router can handle these speeds, but I have my doubts. I've verified with speed tests it's wired to the modem they I'm receiving full speeds, but then when wired to the router I don't get close to them. I've done all of the troubleshooting in this forum and spent weeks now combing through them all for new solutions. Nothing has worked. I feel like I was robbed of the money spent on this router as it has yet to fulfill any of the performance it claims to give.
The forums and other sites are littered with posts of this router not getting full speeds, and of firmware .40 constantly losing internet connection. Yet, nothing but silence from Netgear. The lack of support for fixes to this router, and instead rolling out a more expensive router and updating its firmware show exactly where their priorities are.
- FURRYe38Apr 09, 2019Guru - Experienced User
Are you doing a full factory reset and setup from scratch when upgrading or downgrading FW?
Are you getting 900Mb now with v32 loaded?
Ensure the cable in between the modem and router is of good quality. CAT6 is recommended.
Yes v40 seems to have issues.
You can check the WAN to LAN speeds of the router if you have two PCs and switch:
https://www.duckware.com/tech/router-wan-to-lan-throughput-test.html
- JNewmsApr 09, 2019GuideYes. I always do a full reset after updating or downgrading.
No, I still don't get my full speeds. Like I said, this router has never achieved full speeds.
All of my cables are Cat 6. I went and bought all new cables in October to ensure they were all cat 6 to rule that out as an issue. Like I said, I've combed through everything I could find looking for solutions. Nothing has worked. I'm at my wits end and need to figure out an alternative that works.- Netduma-FraserApr 09, 2019NetDuma PartnerCan you post a full screenshot of your QoS page please so I can take a look
