Julia1976
Apr 11, 2020Aspirant
Which One is the Best Gaming Netgear Router?
Hi, Actually i have 2 routers in my house of other brand. I want to switch Netgear Pro gaming router so hoping help me to guide which one is the best for me. My budget is under $200.
Apr 11, 2020Guru - Experienced User
the R7800 can usually be found on sale for >$200.
That's what I'd recommend for that budget.
Netduma-Fraser
Apr 14, 2020NetDuma Partner
You can get the XR300 which is the cheapest Nighthawk Pro Gaming router for around $200 so that may be the best option for you.
