mrut530's avatar
mrut530
Which unit is better for my home
The nighthawk ac1750 model r6700 or the nighthawk xr500 gamin router.  I have about 25 devices that can be used at one time and looking to see which router is my best option
  • Definitely the XR500 which is based on the R7800 and runs on DumaOS, far better than stock NG firmware. If the XR500 is too expensive for you, consider the R7800
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      That's quite a lot of devices and so depending on your bandwidth you'll likely experience local congestion which the XR500 can eliminate. Also if there are any gamers in the house they will benefit from the XR500 in more ways as well. Full disclosure - you're posting in the NPG XR section and I work for Netduma who created the software for the XR500.
      • mrut530's avatar
        mrut530
        I do not have alot of gamers just kids who love netflix and my wife works from home ----then i have ring and nest devices thru out th ehouse--prob about 20 to 25 items at a time
