Stylz
Jun 05, 2018Tutor
Why am I receiving this "Uncaught Unmatched device"???
WTF am I receiving this error on a $300+ router?
"Uncaught Unmatched device" when I monitor my "GeoFilter"? Ive tried downgrading (why) the firmware version only to receive the same error. Plea...
Netduma-Fraser
Jun 06, 2018NetDuma Partner
I believe an issue with UPnP caused device names to be wiped that were added to Geo-Filter/QoS causing those errors. Firmware has been pulled while Netgear investigate. Factory reset will fix it.
Stylz
Jun 06, 2018Tutor
Wow! So spend more time resetting this $300+ device and re-adding all security, setup MAC address filtering again, set static IPs, etc..
Amazing device:smileymad:
- Netduma-FraserJun 06, 2018NetDuma PartnerRenaming the device to what it was called previously or reconnecting it to the router if it has been disconnected would resolve it. I believe a UPnP change by Netgear may have triggered it which is why its been taken down to be resolved.
- StrangerPingsJun 23, 2018Tutor
LOL, there is no MAC address filtering on this piece of crap, it dumped it routinely so the pulled it in the last firmware update. The arguments I had with tech support were straight out of a comedy.
- KillhippieJun 24, 2018Prodigy
There was no Mac address filtering in 2.2.1.10 either. In fact its the worse piece of so called security you can use. A strong WPA2 AES password is all you need Even hiding your SSID is not worth it as it can be seen by simple program like Netstumbler will show it. Mac addresses can be easily spoofed which is the problem and it can make some devices not connect properly (apple for a start suggest to turn it off), it is truly false security. Have a read of from this link.
https://www.howtogeek.com/204458/why-you-shouldn%E2%80%99t-use-mac-address-filtering-on-your-wi-fi-router/
