Stylz
Jun 05, 2018Tutor
Why am I receiving this "Uncaught Unmatched device"???
WTF am I receiving this error on a $300+ router?
"Uncaught Unmatched device" when I monitor my "GeoFilter"? Ive tried downgrading (why) the firmware version only to receive the same error. Plea...
Schranck
Jun 20, 2018Aspirant
I tried what was suggested and previous comments .still not getting geofilter
Netduma-Fraser
Jun 20, 2018NetDuma Partner
A factory reset will definitely fix it but try this:
Right click on the Devices Panel
Inspect Element
Click the little triangles
You should be able to see the named device, then rename it to this in device manager - see attached picture.
Otherwise factory reset will definitely fix.
