SouthernGypsy
May 14, 2024Apprentice
Why is the Time ALWAYS Wrong?
Just like the title says, the Time on my XR1000v2 (with the latest firmware) is ALWAYS wrong. There are two places to set it; NTP settings under Administation Menu and also the 3 dots in the upper co...
May 15, 2024Guru - Experienced User
Is there a DST check box?
- SouthernGypsyMay 15, 2024Apprentice
Yes, as I said in my post "...and turn on Automatically adjust for daylight saving time, it shows that it's only 8:45pm when in fact it's 9:45pm here now. If I turn off Automatically adjust for daylight saving time, it changes nothing at all, still shows 8:45pm."
DST is just an abbreviation for the daylight savings time that I was reffering to, checking/un-checking box does not change anything. It has no affect at all.
- FURRYe38May 15, 2024Guru - Experienced User
Ya we know what DST stands for.
Seems like that option may be broke or NTP service isn't working right.
FW up to date on the router? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR1000-Version-2-Firmware-Version-1-1-0-16-Released/td-p/2319780/jump-to/first-unread-messageYou have a v2 so not sure if this effects v1's. I can check mine.
So I checked my v1 today and NTP configuration is correctly displayed and accurage for my time zone here:
My router is connected behind another router so in double NAT here. Modem is a CM3000.
I would open up a support ticket with NG and let them know about this and what you see on the v2 XR1000. This maybe a v2 only issue.
