SouthernGypsy
May 14, 2024Apprentice
Why is the Time ALWAYS Wrong?
Just like the title says, the Time on my XR1000v2 (with the latest firmware) is ALWAYS wrong. There are two places to set it; NTP settings under Administation Menu and also the 3 dots in the upper co...
SouthernGypsy
May 15, 2024Apprentice
Yes, as I said in my post "...and turn on Automatically adjust for daylight saving time, it shows that it's only 8:45pm when in fact it's 9:45pm here now. If I turn off Automatically adjust for daylight saving time, it changes nothing at all, still shows 8:45pm."
DST is just an abbreviation for the daylight savings time that I was reffering to, checking/un-checking box does not change anything. It has no affect at all.
May 15, 2024Guru - Experienced User
Ya we know what DST stands for.
Seems like that option may be broke or NTP service isn't working right.
FW up to date on the router? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR1000-Version-2-Firmware-Version-1-1-0-16-Released/td-p/2319780/jump-to/first-unread-message
You have a v2 so not sure if this effects v1's. I can check mine.
- FURRYe38May 15, 2024Guru - Experienced User
So I checked my v1 today and NTP configuration is correctly displayed and accurage for my time zone here:
My router is connected behind another router so in double NAT here. Modem is a CM3000.
I would open up a support ticket with NG and let them know about this and what you see on the v2 XR1000. This maybe a v2 only issue.
- SouthernGypsyMay 15, 2024Apprentice
Mine is correct there in that location (part of why I'm not totally worried about it, but still it's odd the router has two different times in two different locations), but click the 3 dots in the corner, choose advanced, and look at Time Zone there and see if the time displayed there is correct if your in CST in the US.
Here are three locations in the DumaOS you can see the time, notice how one (the pop-out when you click the 3 Dots in the upper right corner > then select Advanced > then select Time Zone) is different than the other two. I took pics showin the pop-out menu poped out over the other time locations in the background so you can see them at the same time and see the one under the 3 dots>advanced>time zone is showing a different time. Oh yea, and sometimes, like in these pictures, it doesn't even show the time zone (though usually does and when it does it's my proper time zone, though the time is still wrong).
