ivan675421
Aug 30, 2025Tutor
Why my geo filter do not work at all
Why my geo filter do not work at all and it is not the first time it do not work ,i always had problems with geo filter with xr1000 router
- Sep 01, 2025
Understood thanks. It doesn't take time for the settings to apply and so currently I can't tell what the issue might have been as it resolved itself. Perhaps a cloud update was needed at the time
Netduma-Fraser
Aug 30, 2025NetDuma Partner
You'll need to provide some more information about what exactly is happening e.g. what device/game you're playing, how you've added that to the Geo-Filter, if you're getting games outside your radius, nothing appearing on the map at all etc
