ivan675421
Aug 30, 2025Tutor
Why my geo filter do not work at all
Why my geo filter do not work at all and it is not the first time it do not work ,i always had problems with geo filter with xr1000 router
- Sep 01, 2025
Understood thanks. It doesn't take time for the settings to apply and so currently I can't tell what the issue might have been as it resolved itself. Perhaps a cloud update was needed at the time
ivan675421
Aug 31, 2025Tutor
I have an xbox series x i play call of duty warzone geo filter is dead ....my xbox pings outside the limits i have set it pings as there is no netduma and also there is no sign on the map of the server it pings to .......and yes i have set it on auto ping ..... I am just about to break this router and never buy again ....it is not the first time that this problem appeared always ....no responce and noresponse this router gives me i think i should buy the netduma router and not the xr1000
Netduma-Fraser
Aug 31, 2025NetDuma Partner
Can you provide a screenshot of your Geo-Filter page, how you have the device added and the Geo-Filter settings also please?
