ivan675421
Aug 30, 2025Tutor
Why my geo filter do not work at all
Why my geo filter do not work at all and it is not the first time it do not work ,i always had problems with geo filter with xr1000 router
- Sep 01, 2025
Understood thanks. It doesn't take time for the settings to apply and so currently I can't tell what the issue might have been as it resolved itself. Perhaps a cloud update was needed at the time
ivan675421
Sep 01, 2025Tutor
I am sorry i can not provide a picture , i tried to but i can not, but i can tell you that after our conversation and after three days we are talking about this problem from today my geofilter works just fine i really do not know how this happened i can not explain this......now about my configuration fot geo filter i have set ....the name of my xbox for distance i have set kilometres for mode strict mode for auto ping host auto for set distance 111 and for ping assist 31 to 33 and the game i have set is call of duty anyway thank you for your help 😊 but i have to say that this problem with geo filter i had it again in past quite often and last my update is1.0.0.74_1.0.63
- Netduma-FraserSep 01, 2025NetDuma Partner
The Xbox should be added as a console, it shouldn't be the game you've selected for it. Remove it from the Geo-Filter and then in the Device Manager make sure the Xbox device type is an Xbox. Then re-add it to the Geo-Filter and it should add as a console. This will then work better more consistently. Also having Ping Assist enabled can allow for games outside your radius.
