ivan675421
Aug 30, 2025Tutor
Why my geo filter do not work at all
Why my geo filter do not work at all and it is not the first time it do not work ,i always had problems with geo filter with xr1000 router
- Sep 01, 2025
Understood thanks. It doesn't take time for the settings to apply and so currently I can't tell what the issue might have been as it resolved itself. Perhaps a cloud update was needed at the time
ivan675421
Sep 01, 2025Tutor
Thank you very much for your advice i really appreciate it. There is a misunderstanding and probably it is my fault i am sorry about this you see i own this router for about 4 years so i have set my xbox device as an xbox at the topof the list i have set the name of my xbox and to the geo filter i have set as games console because there is no choice for xbox to the geo filter.i did mention the game i play because there is a choice to the geo filter which ask you what game you want to choose it is the first question so my problem is why it takes my router so many days to confirm the set up i am giving it.anyway for one more time i want to thank and i am grateful for your response...
Netduma-Fraser
Sep 01, 2025NetDuma Partner
