ivan675421
Aug 30, 2025Tutor
Why my geo filter do not work at all
Why my geo filter do not work at all and it is not the first time it do not work ,i always had problems with geo filter with xr1000 router
- Sep 01, 2025
Understood thanks. It doesn't take time for the settings to apply and so currently I can't tell what the issue might have been as it resolved itself. Perhaps a cloud update was needed at the time
ivan675421
Sep 02, 2025Tutor
Never mind wrong question ,i know how to.... i go to nighthawk app and i check for update ...thanks for everything.
- FURRYe38Sep 02, 2025Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
