Stevediggo
Dec 29, 2021Follower
Wi-Fi poor
Hello all I have been upgraded to VM 600mbs but the router was awful, I purchased the nighthawk XR1000 Router, switched and set up no issues. Hard wired I get max speed, however the Wi-Fi is poor in ...
Dec 29, 2021Guru - Experienced User
extenders still need a decent signal to connect to so it can rebroadcast.
So maybe we should start back at square 1 and figure out whats going on with the XR1000.
How big is your home?
What are the interior walls made of?
When you're the "30 odd feet away" what is in between the route and the device you're testing on?
