Stevediggo
Dec 29, 2021Follower
Wi-Fi poor
Hello all I have been upgraded to VM 600mbs but the router was awful, I purchased the nighthawk XR1000 Router, switched and set up no issues. Hard wired I get max speed, however the Wi-Fi is poor in ...
Netduma-Fraser
Dec 30, 2021NetDuma Partner
Disable Smart Connect and connect to 2.4/5GHz manually, you may also want to use a WiFi analyzer to find the least congested channel and change to that. Where is the router placed exactly, e.g. on the floor, on a metal shelf etc?
