KyleP6912
Apr 17, 2020Aspirant
WiFi and Hardwire speed slow
Im getting 83 mbps upload and 92 mbps download when i use the xr500. When using my isp router im getting 240 mbps for up and down which is very close to what i pay for. My connecting is through a ca...
Apr 17, 2020Guru - Experienced User
What box are you using from frontier? (model)
Have you checked the cable? or replaced it?
Have you manually changed your speed settings in the xr500?
https://kb.netgear.com/000053112/How-do-I-set-up-QoS-on-my-Nighthawk-Pro-Gaming-Router
KyleP6912
I have changed the cable same result. I changed the speed manually in qos and still had same speeds when i tested. The model number is FGO420
- plemansApr 17, 2020Guru - Experienced User
I couldn't find a thing when I looked for FGO420 from frontier. You sure its the model number?
