KyleP6912
Apr 17, 2020Aspirant
WiFi and Hardwire speed slow
Im getting 83 mbps upload and 92 mbps download when i use the xr500. When using my isp router im getting 240 mbps for up and down which is very close to what i pay for. My connecting is through a ca...
KyleP6912
I have changed the cable same result. I changed the speed manually in qos and still had same speeds when i tested. The model number is FGO420
Apr 17, 2020Guru - Experienced User
I couldn't find a thing when I looked for FGO420 from frontier. You sure its the model number?
- KyleP6912Apr 17, 2020Aspirant
here is a image hope this helps
- plemansApr 17, 2020Guru - Experienced User
do you have it set to IPv4 or IPv6?
The device you're testing from, the ethernet port that its plugged into on the router, what color is it?
IPv4 IPv6 was disabled in router settings when i looked.
The cable going from my ont is plugged into the yellow port on the xr500 and the cable coming from the xr500 to my laptop is plugged into a black port
