Thizzlegaming
May 22, 2020Guide
Wifi and lan dropping internet connection xr500
My connection keeps constantly dropping and is very slow I checked to see if my router needs and update and its on the lastest firmware v2.3.2.40 I can't find any solution to this and it's just very i...
May 22, 2020Guru - Experienced User
What modem are you connected to?
Thizzlegaming
May 22, 2020Guide
No modem my internet comes from the wall to the router it's been like this since I bought my house never had issues untill now
- plemansMay 22, 2020Guru - Experienced Userand that ethernet comes from somewhere.
What is it connected to?
Device and who's your isp?- ThizzlegamingMay 22, 2020GuideLocal internet company
Thizzlegaming wrote:
Local internet companyThat response helped not even slightly.
i'm doing my best to help you but you've gotta do a little bit too.Look at where the ethernet cable runs from and figure out what gateway device it is.
Some gateway devices have their own integrated router functions. Which can cause issues/drops when you're running a double nat. Or your isp might require certain settings to function properly. But without some basic information, we'll never know.
