nhanschke
Aug 12, 2021Initiate
WIFI "blocked" after ISP signal interruption
My apologies if there is another thread exists that discusses this issue. Also, apologies if I'm using the wrong terminology, I'm a bit out of my depths here. Over the past couple of years I have...
Netduma-Fraser
Aug 12, 2021NetDuma Partner
It's something that's being fixed currently actually. If you upgrade to the .120 beta then this may happen less as a partial fix was included
nhanschke
Excellent, that's good to know. Thank you very much for the quick reply!
