Retired_Member
Dec 20, 2018Wifi Calling on XR500
Anyone managed to get wifi calling to work on the XR500?
Would appreciate help with config/settings to get it working.
- Netduma-FraserNetDuma PartnerI'd recommend disabling Smart Connect for a start and connecting to the individual bands.
- Retired_Member
Smart connect is disabled and I am connected to the 5GHz band. Anything else I should note?
Is Beamforming enabled? It should be. You can test with MIMO enable or disabled.
160 should be disabled.
