heidarren
Jun 19, 2018Tutor
WIFI devices cannot reach my NAS
I've found that all my WIFI devices will never get connect to my NAS, LAN devices has no problem to reach my NAS
After few tries, I've found that this problem occurs once I have my VLAN on, if ...
Guzo
Sep 07, 2018Aspirant
Any solution for this problem? Got the same issue!
- heidarrenSep 07, 2018Tutor
I added a switch between modem and router to handle VLAN, solved!
- Netduma_JackSep 07, 2018NetDuma Partner
Are you able to try this solution Guzo as there is no fix for this yet. Thanks
