Ant30
Aug 27, 2020Aspirant
WiFi devices disconnect & incorrect password
Hoping someone can help? I purchased the R800P back in January. For around the past month every five to seven days all devices connected via WiFi will disconnect. Strangely, my CCTV remains connected ...
Ant30
Firmware is 1.4.1.62_1.3.22
I have had to reboot it three times this week (turned off and back on) although on todays attempt it didn't work, now the connection to all devices is dropping probably every few hours or so. I have done one factory reset which worked for all of about two weeks, then back to this original fault. It is connected to a virgin media super hub.
thanks for the reply!
Aug 27, 2020Guru - Experienced User
You could try downgrading the firmware a version or 2.
If you downgrade, do it over a hardwired connection, reset the router afterwards, and then manually reinstall.
I know version 1.4.1.50 got the netgear armor update and not all devices played nicely with it. If you tried that one and it has issues, try 1.4.1.42 as it was a pretty solid version of the firmware.
