KeoKillz
Oct 03, 2019Aspirant
Wifi Disconnects when I Live Stream
Wifi Router works perfectly fine up until i go live when i stream. Then it disconnects.
Oct 04, 2019Guru - Experienced User
What is the distance between the router and you streaming devcie(s)?
Try enabling Beamforming and WMM.
Set 20/40Mhz Coexistence to 40Mhz only.
Is Smart Connect enabled or disabled?
KeoKillz wrote:Wifi Router works perfectly fine up until i go live when i stream. Then it disconnects.
- Netduma-FraserOct 05, 2019NetDuma PartnerMy initial thought without much information is you may be throttling too much and therefore not allowing enough bandwidth for your stream. What are your QoS settings?
