J-Schu
Jun 05, 2021Aspirant
Wifi keeps dropping on R7000
I have only had this for a just under 4 months and it keeps dropping wifi. Its getting worse. I had bought this to use instead of the router provided by Spectrum. I need it for work (publishing large ...
J-Schu
Hi!
It's currently connected to the modem supplied our IPS (Spectrum)
I do believe it's been updated to the most current firmware :(
We don't have anything connected directly to it. Our router is on our middle floor but we both have computers and playstations set up on the lower and top level of our apartment.
Jun 05, 2021Guru - Experienced User
J-Schu wrote:
Hi!
It's currently connected to the modem supplied our IPS (Spectrum)---itll have a model number it. that helps more than "a modem from our isp"
I do believe it's been updated to the most current firmware :(-----with the r7000, thats up for debate. thats why we ask. its pretty simple to log into it and view what firmware version its on
- J-SchuJun 05, 2021AspirantOh đ okay. I will find all of that info once I get home and respond with all that đ
