J-Schu
Jun 05, 2021Aspirant
Wifi keeps dropping on R7000
I have only had this for a just under 4 months and it keeps dropping wifi. Its getting worse. I had bought this to use instead of the router provided by Spectrum. I need it for work (publishing large ...
Jun 05, 2021Guru - Experienced User
J-Schu wrote:
Hi!
It's currently connected to the modem supplied our IPS (Spectrum)---itll have a model number it. that helps more than "a modem from our isp"
I do believe it's been updated to the most current firmware :(-----with the r7000, thats up for debate. thats why we ask. its pretty simple to log into it and view what firmware version its on
J-Schu
Oh đ
okay. I will find all of that info once I get home and respond with all that đ
