HuskerBilly
Jan 05, 2024Tutor
Wifi network name changed and no pw requirement (nighthawk pro gaming XR1000)
Last night I reset my modem and router. Both showed fully booted and functional, yet I was not able to connect to network. After 45 mins of troubleshooting and lots of resets, I realized that there w...
microchip8
Jan 05, 2024Master
If you reset a router, it reverts to factory defaults so you get the factory default SSID and password, if any.
- HuskerBillyJan 05, 2024Tutor
Thanks for your reply. I only turned it off and on, not factory reset. Apologies if that wasn't clear. The default network name was NETGEAR19 but it now is just NETGEAR with no pw requirement.
- microchip8Jan 05, 2024MasterSo what's the problem? Set it up again
I just got freaked out I guess that it somehow got hacked. I've never experienced that happen in the past. From your reply I take it I'm overthinking the situation and should just go ahead and reset it to factory settings. Appreciate the replies
