HuskerBilly
Jan 05, 2024Tutor
Wifi network name changed and no pw requirement (nighthawk pro gaming XR1000)
Last night I reset my modem and router. Both showed fully booted and functional, yet I was not able to connect to network. After 45 mins of troubleshooting and lots of resets, I realized that there w...
HuskerBilly
Jan 05, 2024Tutor
Thanks for your reply. I only turned it off and on, not factory reset. Apologies if that wasn't clear. The default network name was NETGEAR19 but it now is just NETGEAR with no pw requirement.
microchip8
Jan 05, 2024Master
So what's the problem? Set it up again
- HuskerBillyJan 05, 2024Tutor
I just got freaked out I guess that it somehow got hacked. I've never experienced that happen in the past. From your reply I take it I'm overthinking the situation and should just go ahead and reset it to factory settings. Appreciate the replies
- microchip8Jan 05, 2024MasterPeople don't just get hacked. Someone has to actually spend a lot of time and resources to breach your network for unknown benefit. More likely your router reverted for some reason to its default SSID.
