Tige
Sep 30, 2022Follower
Wifi password
How do you change your wifi passwords on the nighthawk xr1000 wifi 6 gaming router
1 Reply
Tige wrote:
How do you change your wifi passwords on the nighthawk xr1000 wifi 6 gaming routerHow do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Manuals are also a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
