lverberkt
Nov 05, 2019Aspirant
WiFi problems with Netgear nighthawk R7800
Hello, I'm having issues with my wireless connections, 2.4 and 5 ghz. The WiFi is enabled according to the second light of the right is on. When I login with routerlogin.net I see wireless warning off...
Netduma_Alex
Nov 06, 2019NetDuma Partner
Under Wireless Settings, have you hidden the SSID? Are you using Smart Connect?
- lverberktNov 06, 2019Aspirant
Hello,
network is not hidden and smart remote is enabled.
